How to edit a block with visibility of main drawing in AUTOCAD??? Nilanjan Chakraborty 28 Jan, 2013 07:07 AM Using process of block editor in place. 1 Answer f1d9f997 Answered on 10 Jun, 2013 12:53 PM hello my friend it's easy way you can use "refedit" command and select your block and edit your block after finish you can use "refclose" command good luck
