How to fix STEP conversions
By Karl Ebert on 14 Apr 16:38 4 answers 589 views 9 comments
I downloaded some STEP files and opened them in Inventor, but they're transparent, I can't change the color, and when I put them in a drawing, they don't show up. Does anybody know what happened?
  • w.wolf
    w.wolf about 1 year ago
    I think the models you've downloaded were made with surfaces not solids.
    Right click on the surface and then on 'Translucent'.
  • ALI
    ALI about 1 year ago
    which file did you use?
  • ALI
    the file is not STEP, it is IGES. I think the problem is how that iges was saved and how Inventor kernel read it. anyway I saved it as Stp. try this file.
    AR15_Lower_Receiver.STEP, 2.53 MB
    Download
  • Greg Pavlik
    Greg Pavlik about 1 year ago
    The composite files that come up transparent can be solved pretty easily, just right click the mouse and a list should come up. In this list you should see tranparent right by the visibility button, just click it off. If its transparent that usually means its a surface model though so you will be limited in what you can do with it.
Add your answer to: "How to fix STEP conversions"
