How to hide or remove the pcd & axis lines from the drawing? proe 5
Hiding or removing the pcd & center lines from the drawing how?there is any option
i turned off the datum planes,axis lines,etc.. but i could not hide,i also check the layers
but no use.
these tapped holes and holes are patterned, there is any settings need in dtl file.
I need to show slot axis in model as well as in drawing.I can create a axis by creating geometry point axis when draw a sketch.but i need to create a axis with out geometry point axis.i found a another way to create a slot axis by adding "show_axes_for_extr_arcs" to yes in creo config file.
But unfortunately it is does't work.
Please help me to create slot axis by creo config file option.
