How to import 3D PointCloud data to SolidWorks without making the software crash?
By Selcuk OZMUMCU on 20 Jan 23:35 6 answers 3352 views 2 comments
I tried to import a small 3D scan -point cloud- data from a friend, just to test SolidWorks' skills on Point cloud, but I couldn't even manage to open any file properly.
I read SolidWorks' documentation, and tried and tried again, but got nothing.
We tried several point cloud formats and again got nothing?
In the documentation, it is showing highly detailed cloud data being converted into 3d solid geometry, however, we couldn't even achieved it with tiny piece of data.
Is there a special procedure to follow.
And got suspicious about Solidworks skills on the issue.
Thanks in advance,
  • Dave Feathers
    Dave Feathers over 1 year ago
    Do you run the premium with scan to 3d?... NO?... then download the free "meshlab" software to transfer file formats and clean up scan data prior to solidworks. Good luck.
  • Cliff Behrend
    Cliff Behrend over 1 year ago
    SW Premium is required
    Turn on Scan to3D in Add-ins
    Then open your point cloud file
    Start Mesh Prep Wizard
    Oriet your point file around origin and planes
    Cleanup mesh as required
    Adjust resolution as required
    Begin meshing
    Fill holes
    Start Surface wizard
    http://video.google.com/videoplay?docid=-1635643449149352968#
    If your model is to far away from the origin it exceeds SW volume restriction
  • Selcuk OZMUMCU
    Selcuk OZMUMCU over 1 year ago
    Hi Dave,
    Of course it was Premium version of SolidWorks. But whatever we tried to make SolidWorks kept crashing!
    On the other hand, I didn't know that software ( meshlab). Thanks for the advise.
    Regards,
  • Selcuk OZMUMCU
    Hi Cliff,
    Thank you for the step by step advise. I will try it again.
    My friend gave me tiny piece of a very big model, may be it exceeded the SW volume restriction as you said, may it was the problem.
    If I have the chance to test it again, I will let you know about it.
    Regards,
  • Cliff Behrend
    It is important to center drawing at origin to keep volume down
Add your answer to: "How to import 3D PointCloud data to SolidWorks without making the software crash?"
