Rocker Arm Assembly in an Engine
I am assembling a single cylinder engine and most parts are cnstrained and working properly. But for the rocker i find it difficult to make it constraint so that it moves in its desired direction.
Help me how to constraint it to perform its function.
I have attached the screenshot. Thanks in advance :)
Accepted answer
Please create an axis on the plane at your desired location to fix the rocker and constrain geometry will works.
0 Other answers
