SOLIDWORKS ANGLE LIMITS MATE BUT MAKE IT STOP WHEN IT COMES TO ANOTHER PART
WITH ANGLE LIMITS YOU AND ROTATE A PART IN X AGGLES BUT HOW DO YOU MAKE IT STOP WHEN IT COMES TO ANOTHER PART. I WANT THIS TO STOP WHEN THE FACE MEETS THE ROUND FACE
eğer yanlış anlamadıysam sorunuza cevap olabilir. ( montaj ilişkilerinde gelişmiş montaj ilişkisi seçeneği ile istediğiniz dereceler arasında sınırlandırabilirsiniz bu şekilde daha doğru olur)
Hello,
You have many options, and I am going to say two of them:
First, you can easily limit you angle by using Mate>Advanced mates>Angle limit> and then carefully insert the minimum and the maximum values there.
Second, you can use the limit angle mate and then in the entities to mate, for instance, if your parts are perpendicular, select one part's top plane and then another parts right plane and not the faces you need to limit the angle. OR selects one face of part 1 and a plane of second part.
It would be way easier to response, if you had uploaded a picture of what you need to mate.
Regards
