Tutorial: How to make engine part 30
By Aykut Dana on 29 Aug 21:47 4 answers 3722 views 8 comments
I separate the sections so you can easily follow the tutorials.
CYLINDER HEADS
Added images
Square
  • Aykut Dana
    Aykut Dana 9 months ago
    CYLINDER HEADS
    1. Step 1
      make same things for the other side. dont forget the select bigger circles.small ones for the cut-loft command. if your loft be like this, go to top view, drag and drop the green points. make them parallel
      Medium
    2. Step 2
      place your green points like this
      Medium
    3. Step 3
      select the centerline
      Medium
    4. Step 4
      show the sketches
      Medium
    5. Step 5
      go to right view and open a 3D sketch
      Medium
    6. Step 6
      draw shown lines they will be used for to create new planes
      Medium
    7. Step 7
      go to top viev and insert these lines
      Medium
    8. Step 8
      isometric view of the 3D sketch. please check
      Medium
    9. Step 9
      use referance geometry--plane command. click on shown lines and confirm that
      Medium
    10. Step 10
      use same command again and create a new plane like shown
      Medium
    11. Step 11
      open a sketch on the plane 3
      Medium
    12. Step 12
      draw a circle like shown. it have to be coincident with shown circle
      Medium
    13. Step 13
      extrude it by 50mm
      Medium
    14. Step 14
      open a sketch on the plane 4
      Medium
    15. Step 15
      draw a circle like before
      Medium
    16. Step 16
      extrude it 50mm
      Medium
    17. Step 17
      open a sketch on the blue surface
      Medium
    18. Step 18
      draw a 4mm radiused circle
      Medium
    19. Step 19
      use cut extrude command like shown
      Medium
    20. Step 20
      go to other side, open a sketch and draw a circle again
      Medium
    21. Step 21
      use cut extrude command again like shown
      Medium
    22. Step 22
      Medium
    23. Step 23
      Medium
    24. Step 24
      show the sketches
      Medium
    25. Step 25
      Medium
    26. Step 26
      Medium
    27. Step 27
      Medium
    28. Step 28
      Medium
    29. Step 29
      Medium
    30. Step 30
      Medium
    31. Step 31
      Medium
    32. Step 32
      Medium
    33. Step 33
      extrude it by 50mm
      Medium
    34. Step 34
      Medium
    35. Step 35
      Medium
    36. Step 36
      extrude it 50mm
      Medium
    37. Step 37
      Medium
    38. Step 38
      Medium
    39. Step 39
      Medium
    40. Step 40
      Medium
    41. Step 41
      next: http://grabcad.com/questions/tutorial-how-to-make-engine-part-31
      Medium
Add your answer to: "Tutorial: How to make engine part 30"
