Tutorial - Jog feature (Sheet-metal) in SolidWorks?
By Sudhir Gill on 16 Feb 06:11 1 answer 1022 views 0 comments
Tutorial on Jog feature in sheet-metal in SolidWorks.
1 answer
  • Sudhir Gill
    Sudhir Gill over 1 year ago
    Here is the Tutorial.
    1. Step 1
      Start SolidWorks in part mode.
      Medium
    2. Step 2
      Top plane>>Sketch.
      Medium
    3. Step 3
      Draw a rectangle.
      Medium
    4. Step 4
      Under Sheet metal tab click Base flange/Tab.
      Medium
    5. Step 5
      Keep the default settings and click OK.
      Medium
    6. Step 6
      Under Sheet metal tab click Jog.
      Medium
    7. Step 7
      Select the top face of the base flange.
      Medium
    8. Step 8
      Create a line at 60º angle.
      Medium
    9. Step 9
      Exit the sketch. Now the Jog property manager will show.
      Medium
    10. Step 10
      Select the fixed area. The black dot represent the fixed area.
      Medium
    11. Step 11
      Change the Jog offset distance to 30mm and click OK.
      Medium
    12. Step 12
      Now we have the Jog feature obtained.
      Medium
Add your answer to: "Tutorial - Jog feature (Sheet-metal) in SolidWorks? "
