Tutorial - Making a helical gear in AutoCAD?
By Sudhir Gill on 07 Feb 06:55 2 answers 3016 views 2 comments
Tutorial on making helical gear in AutoCAD 2011.
  • Sudhir Gill
    Sudhir Gill over 1 year ago
    Here is the tutorial
    1. Step 1
      Start AutoCAD.
      Medium
    2. Step 2
      Make a circle of 35mm radius at center.
      Medium
    3. Step 3
      Make another circle of 50mm concentric to previous one.
      Medium
    4. Step 4
      Make two arcs like this one for cutting teeth.
      Medium
    5. Step 5
      Trim down the circles. Now enter PEDIT command.
      Medium
    6. Step 6
      Right click on the screen and select multiple.
      Medium
    7. Step 7
      Select all arcs.
      Medium
    8. Step 8
      Press enter and keep the input Y and press enter.
      Medium
    9. Step 9
      Now click on the join.
      Medium
    10. Step 10
      Press Enter.
      Medium
    11. Step 11
      Now we can see that it has become a polyline.
      Medium
    12. Step 12
      Enter helix command.
      Medium
    13. Step 13
      Enter the radius value of (0,35). Any other value will distort the sweep. Keep the default value for the upper radius. Press Enter.
      Medium
    14. Step 14
      Now select turns and enter a value of 0.15.
      Medium
    15. Step 15
      Now enter a height of 50mm. We have helix path generated which will later be used for cutting the teeth.
      Medium
    16. Step 16
      Create a circle of 50mm with origin as center.
      Medium
    17. Step 17
      Extrude it by 25mm.
      Medium
    18. Step 18
      Enter SWEEP command.
      Medium
    19. Step 19
      Select the polyline to sweep and press enter.
      Medium
    20. Step 20
      Right click and select alignment.
      Medium
    21. Step 21
      Select No.
      Medium
    22. Step 22
      Again right click and select twist.
      Medium
    23. Step 23
      Keep the default values and press enter. Now select the helix as the sweep path.
      Medium
    24. Step 24
      We have one cut body generated.
      Medium
    25. Step 25
      Now enter array command.
      Medium
    26. Step 26
      Select array type polar and enter origin as center for array. Click select object and select the sweep. Now enter the no. of items be 10. Click OK.
      Medium
    27. Step 27
      Subtract the arrayed sweeps from the cylindrical body and we have the helical gear created.
      Medium
  • rockroad
    rockroad 5 months ago
    good I finished the job by 2008 thanks
Add your answer to: "Tutorial - Making a helical gear in AutoCAD? "
