Which is the best free software for generating CNC part program?
By Sudhir Gill on 05 Jan 08:50 7 answers 4465 views 5 comments
for learning purpose.
  • Per Bj. Bro
    Per Bj. Bro about 1 month ago
    The question is a bit vague. Remember that you will need to generate a model in a CAD program (if you are working in 3D), then transform the model to G-Code using a CAM program, then use the G-Code to operate your CNC mill or lathe. For generating your 3D model, I recommend FreeCAD as an open source product. If you want to pay, you can use Inventor, or SolidWorks or many of the other commercial programs.
    The next step is your CAM program. Unfortunately this step is the weakest in open source programs. You can try PyCAM to generate your tool path if you need a free product. MasterCAM is just too expensive; SprutCAM is a good program and costs just USD1500, but only runs under Windows.
    The third step is you machine interface. Mach3 is very good; it costs USD150 and is widely used / pirated. EMC2 is great, it's free and runs under Linux.
  • Martin Camirand
    Martin Camirand over 1 year ago
    There is no magical program to generate a cnc program, for each one I've try you have to know your way around and what you are doing to get a good results. Personnally I had good experiences with mastercam but i'm sure there is some other good software around.
  • Nicolas Garneau
    Nicolas Garneau over 1 year ago
    I use MasterCam everyday, it's versatile and powerful. I would recommand it without any doubt. I know delcam also make good product like powermill and featurecam, collegues had used these software and were pleased. The limitation of Mastercam is that it's not parametric, if you make a change to your model you have to reimport it insede mastercam and reasign the operations to the geometry. If possible try to go with something integrated inside your CAD software like mastercam for solidworks or delcam for solidworks. NX has a built-in cnc porgramming software wich is very powerful I used it at school
  • RICH GILLEN
    RICH GILLEN about 1 year ago
    CHECK OUT MACH3($175) http://machsupport.com/, FREE DEMO VERSION DOES 500 LINES OF G-CODE. DXF TO G-CODE. EMC IS FREE. TURBOCAD/CAM V14 $200 ON EBAY.
    E-MAIL ME, I CAN GIVE YOU SOME OTHERS.
  • Nicolas Garneau
    Nicolas Garneau about 1 year ago
    I just found out HSMXpress. It's free and integrated in SolidWorks as long as you have a legal version. http://www.hsmworks.com/hsmxpress/
    I downloaded and tested the software without generating any code because the post-processor for my CNC does not exist.
    The software is verry well integrated in SW and I could program simple 2,5D parts in just minutes.
  • yourfrienddaedalus
    yourfrienddaedalus about 1 year ago
    MasterCAM is very expensive and extremely troubled software. None of the software mentioned in this thread is completely free because there are not many options and even fewer are of quality.
    I will not make a recommendation based on the performance of the software as I have not examined the items on the following list. But these softwares are free or open source.
    MecSoft FreeMILL
    GNU Computer Aided Manufacturing
    HeeksCNC
    CollabCAD
    As Nicolas mentioned before HSMXpress is free for users of SolidWorks who hold a valid license and, honestly, it is the most viable option. The world of free Manufacturing software is a very ugly place and considering how ugly the commercial software normally is, it is safer to invest in a well-recommend inexpensive entry-level CAM solution.
  • Shaun Marsh
    Shaun Marsh 8 months ago
    I think CNC router is the best for generating cnc part program.It is very good & easy to use.CNC routers are the machines that are used in a number of ways.
    Used CNC Router
Add your answer to: "Which is the best free software for generating CNC part program?"
