Why can't I add a second Revolute Joint for my Gear Joint?
The title says it all. I tried making two revolute joints and then selecting them on the gear joint window, and I tried selecting gear joint and creating two revolute joints from that window, but they both didn't work.
You can see the product on the attachment file.
Take a look at my cursor in the "Revolute Joint 2" attachment.
I think the Gear Shaft Parts are unnecessary. I would delete both instances, and draw them as part of the fixed Base.
Then add both Revolute joints between the Gear and the Base.
Don't forget the Gear joint.
