how can make a simple ball bearing?
By Junaid Yusuf on 24 Nov 08:46 2 answers 1156 views 0 comments
ball bearing with mechanism connection
  • Paul Wyndham
    Paul Wyndham over 1 year ago
    The bearing have to races in it. Usually one is fixed and the other rotates. Use a pin connection to place the moving race into the fixed race. If you are not designing bearing you don't need a fully detailed model. This answer was using Pro/E terminology.
Add your answer to: "how can make a simple ball bearing?"
