How to build custom property tab for edgebanding?
By Constantin on 19 May 21:31 0 answers 235 views 0 comments
I try to create custom property tab for edgebanding,
I created a custom list in the "file property" menu, at "custom" and finished with "edit list" button. In the "Edit custom property list" I created length, thickness and width.
After creating an element, I assigned length, thickness and width (Property Names) to the Value / Text Expression. That's OK but I wish I could edit these values as I am designing wooden parts that require edgebanding (for example ABS). In this case, for example using 2mm ABS, let's say the length must be 2mm less to receive the required length at the end (after edgebanding). Therefore it would be useful to edit the values in the property tab.
Thanks in advance for your answers!
Add your answer to: "How to build custom property tab for edgebanding?"
