BASIC TUTORIAL TO CREATE A CYLINDER & TEXT ON IT.
CTRL+I - ISO view.
CTRL+H - Sketch view.
Right click - Accept.
Middle click - End command.
Step 1
Start Solid edge with a new ISO part model.
Step 2
Select FRONT plane.
Step 3
Draw the below sketch.
Step 4
Then EXTRUDE symmetrically to 200mm.
Step 5
In RIGHT plane create a TEXT using TAXT PROFILE tool ....
Step 6
Place it at center.
Step 7
Using project in SURFACING TAB.. You can project the TEXT on the cylindrical surface..
1.sketchStep 8
2.surface
Step 9
3.Direction & FINISH.
Step 10
Text on Cylinder.
