How to edit CATIA file format in Autodesk Inventor 2013 or Fushion?
I have get CAT file from my customer and need to use the part for lower die and upper forming punch block..Please help me solve the problem..
You can try to follow the same basic idea that I outline in my answer to your other question.
http://grabcad.com/questions/how-to-extrude-to-next-using-cat-file-in-inventor-2013
There are some free ONLINE courses for Fusion at http://www.myigetit.com
Fusion would probably be the best solution you could create a part for each station in the progressive die.
Good luck!
Hi Faisal I am not to sure you can edit the Catia part in IV as it will still come in as a 3rd party part.... Hmmmmm
Hahaha thank you for this question as it has now giving me a little bit of education I did not know about after I had to do a little bit of reading up there.
:P
http://autodeskmfg.typepad.com/blog/2009/09/working-with-catia-data-in-autodesk-inventor.html
