How to make and assembly a Pillow Block using Solid Edge
Hi GrabCad Community!
This is my first tutorial entry on this challenge. During this tutorial I will try to explain how to model and assembly a Pillow Block using Solid Edge ST4.
Link to CAD-file: Pillow Block Ø100 mm
So are you ready? Let’s begin! ;)
4 Answer
PART 2
I think that at this point you are able to design the upper part of the Pillow Block and in this second part of the tutorial I focus on how can you assembly a model. To follow this tutorial download my Pillow Block model that contains all parts we will use now.
Answered with a tutorial: https://grabcad.com/tutorials/how-to-make-and-assembly-a-pillow-block-using-solid-edge--1
This is part 1 of my tutorial where I will try to explain how to model the base of the pillow block. Resuming I will show you how to:
- Define where you want to do your sketch using coincident or parallel planes
- Will see how to draw geometries and how to dimension and use geometric relations
- Create features using Extruded, Extruded-Cut, Revolve, Revolve-Cut and MIrror
- Make a thread hole.
very good tutorials should do it well for a beginner, to have a performance and so learn to use the program. regards
how to download the upper part???/////
