How to make belt mechanism in pro e?
By EDISON PHOENIX on 21 Apr 03:33 2 answers 2182 views 7 comments
  • EDISON PHOENIX
    EDISON PHOENIX about 1 year ago
    Belt tutorial.
    1. Step 1
      Create the base feature.(pulley)
      Medium
    2. Step 2
      Open a assembly model.
      Using pin joint connect the first bulley.
      Medium
    3. Step 3
      Connect the second pulley with pin joint.
      Medium
    4. Step 4
      Go to Application menu->Mechanism.
      Medium
    5. Step 5
      Click belt mechanism and give the smaller and larger pulley diameters.
      Medium
    6. Step 6
      Set a servo motor to a desired pulley.
      Medium
    7. Step 7
      Click Mechanism analysis.
      Then Run the mechanism.
      Medium
  • Bab Anand
    Bab Anand about 1 year ago
    it's own work
Add your answer to: "How to make belt mechanism in pro e?"
