How to make belt mechanism in pro e?
Belt tutorial.
Create the base feature.(pulley)
Open a assembly model.
Using pin joint connect the first bulley. -
Connect the second pulley with pin joint.
Go to Application menu->Mechanism.
Click belt mechanism and give the smaller and larger pulley diameters.
Set a servo motor to a desired pulley.
Click Mechanism analysis.
Then Run the mechanism.
