Is it possible to place dimension value manually in between the dimension line in Solid Works?
Please find the attached image. If I want to move and place the dimension value (150) to the left side is it possible? It is not a huge issue. One of my friends asked me this question. Then I tried, but it doesn’t works. That’s all.
You can simply drag the number "150" and drop where ever you want .as also can be left side..
or your question is not fully clear, so give me more detail of your problem
Answered with a tutorial: https://grabcad.com/tutorials/is-it-possible-to-place-dimension-value-manually-in-between-the-dimension-line-in-solid-works
