Is it possible to place dimension value manually in between the dimension line in Solid Works?
Small
You can simply drag the number "150" and drop where ever you want .as also can be left side..
or your question is not fully clear, so give me more detail of your problem
    This is simply drag and drop method.
    Same method
Please log in to add comments
