Tutorial: How to use emboss feature in Autodesk Inventor?
By Abhijeet on 20 Feb 16:23 3 answers 3000 views 2 comments
Tutorial to use emboss feature in Autodesk Inventor.
  • Abhijeet
    Abhijeet over 1 year ago
    1. Step 1
      I'll be explaining to use this feature using a spherical model. However this can be useful in many other irregular surfaces also.
      Medium
    2. Step 2
      Create a plane offset from the original planes at a distance greater than the radius of the sphere.
      Medium
    3. Step 3
      Enter the dimension. Click OK.
      Medium
    4. Step 4
      Invoke a sketch on the newly created plane and click on "text".
      Medium
    5. Step 5
      Enter the text and format it according to your requirements. Click OK.
      Medium
    6. Step 6
      Position the text by using dimensions. Click ok.
      Medium
    7. Step 7
      Finish sketch.
      Medium
    8. Step 8
      Click on the emboss command.
      Medium
    9. Step 9
      Select the text as the profile. Click on "emboss from face",provide a depth,change the direction if required. click ok.
      Medium
    10. Step 10
      This is the result for "emboss from face"
      Medium
    11. Step 11
      Click on "engrave on face". click ok.
      Medium
    12. Step 12
      This is the result of "engrave on face"
      Medium
    13. Step 13
      Use "emboss from plane" .Provide a taper angle if required. click ok.
      Medium
    14. Step 14
      This is the result of "emboss from plane" . Hide the plane when finished.
      Medium
  • Wes
    Wes 11 months ago
    Emboss can also be used to place sketched shapes onto irregular geometry. It is a handy method for designs on the sides of tires (and tire treads) as the 'wrap to face' check box makes the embossed shape uniform height to the surface.
  • Wes
    Wes 6 months ago
    This tire is an example of both text and profile emboss on different shapes.
    Inventor 2013 part format
    Tire-Emboss_Sample.ipt, 5.81 MB
    Download
Add your answer to: "Tutorial: How to use emboss feature in Autodesk Inventor?"
