Tutorial: How to use emboss feature in Autodesk Inventor?
Tutorial to use emboss feature in Autodesk Inventor.
    I'll be explaining to use this feature using a spherical model. However this can be useful in many other irregular surfaces also.
    Create a plane offset from the original planes at a distance greater than the radius of the sphere.
    Enter the dimension. Click OK.
    Invoke a sketch on the newly created plane and click on "text".
  5. Step 5:
    Enter the text and format it according to your requirements. Click OK.
  6. Step 6:
    Position the text by using dimensions. Click ok.
  7. Step 7:
    Finish sketch.
  8. Step 8:
    Click on the emboss command.
  9. Step 9:
    Select the text as the profile. Click on "emboss from face",provide a depth,change the direction if required. click ok.
  10. Step 10:
    This is the result for "emboss from face"
  11. Step 11:
    Click on "engrave on face". click ok.
  12. Step 12:
    This is the result of "engrave on face"
  13. Step 13:
    Use "emboss from plane" .Provide a taper angle if required. click ok.
  14. Step 14:
    This is the result of "emboss from plane" . Hide the plane when finished.
Please log in to add comments
