CAD Macro/Automation
Created by ashish kumar on 8 May, 2018
VBA Error : Extraction front view with reference to axis system and its plane.
I am recording a macro but facing an issue while running it.
I created an axis system in 3D.
And now I am extracting a front view by first selecting the axis and then its plane so that UCS of that view will be that axis.
but after recording and running the same program again it is showing an error.
below is the script.
Sub CATMain()
Dim drawingDocument1 As DrawingDocument
Set drawingDocument1 = CATIA.ActiveDocument
Dim drawingSheets1 As DrawingSheets
Set drawingSheets1 = drawingDocument1.Sheets
Dim drawingSheet1 As DrawingSheet
Set drawingSheet1 = drawingSheets1.Item("Sheet.1")
Dim drawingViews1 As DrawingViews
Set drawingViews1 = drawingSheet1.Views
Dim drawingView1 As DrawingView
Set drawingView1 = drawingViews1.Add("AutomaticNaming")
Dim drawingViewGenerativeLinks1 As DrawingViewGenerativeLinks
Set drawingViewGenerativeLinks1 = drawingView1.GenerativeLinks
Dim drawingViewGenerativeBehavior1 As DrawingViewGenerativeBehavior
Set drawingViewGenerativeBehavior1 = drawingView1.GenerativeBehavior
Dim documents1 As Documents
Set documents1 = CATIA.Documents
Dim partDocument1 As PartDocument
Set partDocument1 = documents1.Item("Part1.CATPart")
Dim product1 As Product
Set product1 = partDocument1.GetItem("Part1")
drawingViewGenerativeBehavior1.Document = product1
Dim axisSystem1 As AxisSystem
' No resolution found for the object axisSystem1...
drawingViewGenerativeBehavior1.SetAxisSysteme Nothing, axisSystem1
drawingViewGenerativeBehavior1.DefineFrontView 0#, 1#, 0#, 0#, 0#, 1#
drawingView1.X = 594.5
drawingView1.Y = 420.5
drawingView1.[Scale] = 1#
drawingViewGenerativeBehavior1.Update
drawingView1.Activate
End Sub
Please check the script and help me out.
Thanks in Advance.
