what is the use of mapkey in pro e or creo elements?
Follow the steps to create a shortcut using mapkey
Answered with a tutorial: https://grabcad.com/tutorials/what-is-the-use-of-mapkey-in-pro-e-or-creo-elements
Essentially a mapkey is a recorded short cut of buttons/clicks to perform a certain function you repeatedly use.
I missed a thing after opening pro e window just click the shortcut key u created
u will directed to command u have created.
Thank u prabhakaran it so use full for event time and i have fast click on keyboard.................
Tip: When you want to select for example all axis or planes the search function works very well in mapkeys
map keys are used for short cuts
In this we record the operation with single letter
e.g:for revolve operation we set shortcut in mapkey as "R"
when u want to revolve the part, then you simply press "R"
