I have a lot of the body and mechanics worked out on the seats, power supply, landing gear...looking for help on the props and motors for the upper section.
using tried and tested power supplied by a magnetic motor, its range would be nearly endless.
composite materials with comon bonding would make it sturdy as a tank.
Im not a electrical engineer, but i am sure i can find one that can intergrate the electronics so that it would be a true drone...
the magnetic motor can put out 100kvw... anyone have compact high output motors?
question, how to calculate motor for drone design, please give know-how.
I give to sample motor, if to have cad 3D motor for drone design, thank you.
still working on that....i just started this desing a month ago. I am next going to work on getting parts scaled down, 3D print....then work on the motor sizes....
good job, note thank
one more point to add that is when its not in flight, it can power one or more homes...
Matt ;
I posed the question of a passenger drone over 3 months ago and no one answered up until yesterday when you inquired.
Now that you actually posted something, it gets others motivated to get involved and stop being bench warmers.
Good job for the initiative !
And don't forget to upload your models to grabcad !
Steven
I'm need to select the specification of drone motor.
This is a small part of a much larger design project i have been working on... i also have a mini sub thats also apart of the project...i will work on uploading models..
I work in turbocad...have to convert to dxf's
Note, with thank , please give to cad3D model,
a stl was added on my profile...be curious how it looks on anothers computer once they download and rasterize it...
thank you,
