HVAC & Refrigeration Engineering
Created by Evgene Enipra on 20 March, 2019
How to deisgn INTERNAL HELICAL GEAR in SW-12
Can any one know how to make internal helical gear and pinion by using of EQAUTION?
if know pl help me, how to do it?
Thanks in Advance
internal helical gear is not available in solidworks toolbox. the easiest way is using geartrax.
using equation is not a reasonable way. as you should know the exact equation for each gear. but if you want to test that insert your equation in
"Tools> sketch entities> equation driven curve"
you Can Use geartrax for design to many type of gear
www.camnetics.com/geartrax/index.htm
