Hello ,
Im a student .Recently im working on my research project.So, as a part of it iake small animation in keyshot.I try to render it using my pc.But, it shown 10-20 min render one frame.But, i have total 426 frames to render.So, it will take comparely very long time.So, anyone can help me to do this?
Hi manoj,
to reduce the overall time you could set a time limit for each frame. Select "Maximum time" from the Options tab in the Render menu and add 30 seconds per frame - resulting in ~3.5h overall time. If you're not sure if the quality would be good enough render few still images (JPEGs) at random time frames throughout the animation (let's say 2 at the beginning, 2 at the middle and 2 at the end) and check the quality. Depending on the result try increasing or decreasing the time limit per frame to meet your expectations. Once you're happy with the result proceed with the complete animation.
Good luck.
Thankyou very much for your answer , ill check it
I render try and want render it in 1920x1080 quality
Hey Manoj,
10 to 20 min for a frame is normal time for a good quality render. You have to do this as it is. I can help you in rendering this, but no one is going to give you 50 to 60 hrs for free. Contact me if interested. It is better to do by yourself.
