I need a type of metal attractor and its program to help me recover metals from the waste mineral and the mineral waste using electricity and electronics system.
Where are you collecting it from? Are you trying to pick it up while it is on a belt conveyor, or falling through a chute… Usually magnetic separators work the best, but there are many different types.
Thanks Antony will check it and back to you soon.
In a pipe and a chute.
Thanks Johan, Microwaves or quantum waves can work.
Hi Bob, its precious metals in general platinum group metals.
you could use electrolysis to pull the metal from liquid. Use a similar metal as the positive and any metal for the negative. You could also use a micron screen filtering to remove contaminants from the liquid.
Unless it is ferrous materials in a pure form that can be separated with a magnet, there is no dry process using some special material that will separate it out.
Hi Bob, I have to come up with it from all this wet systems I have to form a dry system and it will be the first to serve in mineral processing
