Jimmy Cho
my problem is that;my UE transmits SR to EnodeB but I have SR fail it means the EnodeB not collecting / recognizing / detecting SR reques...
Jimmy ;
I don't know if this is a hardware (signal), firmware (fgpa, bios, dsp, cpu, mcu), or software (C, pyton, java, etc) problem.
So first you need to fault isolate to one of the domains.
Then you need to fault isolate within the domain.
This is YOUR problem not our responsibility, so you need to have as much exact clarity before any problem can be resolved.
I don't see any clarity in what you are asking, so its a guessing match at this point.
Go back to the basics and see what does work and trouble shoot to find out when it breaks with the minimal configurations.
If you didn't design this, then get help from those who did.
Steven
