Hi
I need design help
I want to prove a spur gear can move once and a magnet gear can move 2 times
here is what it would look like
https://photos.app.goo.gl/wcmAoUeH7VuqNdME7
I hope you like what i share
thanks for letting me post
James, I think we are going to need more information about what you are asking. I looked at your pic and it would appear that you are showing us one gear with teeth all the way around and another that has teeth only part of the way around. Are you asking about the ratio between the gears? and I'm not sure at all what you are calling a "magnet gear" If possible please label your drawing and that might help as well.
thanks Mark
If you put a magnet on the one with a half circle the magnet will make the half circle complete a turn when it repels another magnet
This will let the magnet gear do one turn when the non magnet gear does a half turn
So when the non magnet gear does a full turn
The magnet gear will do 2 turns
And when a 2:1 is put on the magnet gear the magnet gear will have more torque then the non magnet gear and will move 1:1
Thats the idea
Hello everyone I am Yusuf and i need help with the blueprint of this "Modelling of a Robotic Grabber in SolidWorks" i search the whole internet but i wasn’t able to find the blue print can u help me guys thanks 😊
Very strange scheme...
How will the gears synchronize when the teeth disengage?
The torque on the gear with the magnet when disengaged will depend only on the strength of the magnet and not depend on the torque on the drive gear.
Please explain in more detail what you want to prove.
They blocked my account
Jameskennymatheson@gmail.com ui an't reply to anyone
If you want to discuss this write me
Please write me at jameskennymatheson@gmail.com
The teeth can have lock and release so they engage
Please write me
This is actually not related to the post, but here I am assuming that it is okay to give you a good reply nonetheless. Send me a mail on james.o.oluwadare@gmail.com
