1-Best website to get the standard dimensions of Bearing Housing?
2-
If I have a shaft of X diameter, How do I choose the suitable ball bearing housing for it?
Its relevan easy to pic. Try skf home page for coplete dimentions of housing also i wan to add that youdont need to make a model you candownload it from eg. skf
As far as picking.. You also need to know load of axle and type of bearing you want to use depenting onthe working contitions. It has a few tricks contact me for more info
Already checked skf but wasnn't sure of the results i got as the maximum written diameter of the shaft was 35 mm for the oval type in the pdf I downloaded
Problem solved now.
Thank you!
but yes I would love to have your skype if possible kindly ^_^
