hey guys
i have some problems when i try to export an assembly from solidworks to MatLab
first i don't find a XML extension to save as
then when i try to import it from matlab an error message is desplaying
i hope you can help
thanks
hello, I have just install simscape, and imported an assembly to Mat lab
at first you should confirm that the simscape version you have enrolled, be match by your Mat lab
and Not only it doesn't need to use "save as" command!, but also you must refer to Tool bar, Si mechanic Links, and export it to Sim Mechanic Generation. the M file and simscape block diagram will create automatically
I also have same problem I have robot arm and i want to import that via simscape but neither i can find XML not export option in my solidworks.
matlab does not support that file
what sould i do to fix the problem please ?
