Watch the tutorial...👍
It is Used to create the curve in spline or planar surface ....the sketch plane must be perpendicular to the spline or planar surface.....
Wrap feature creates only closed contour curve....no intersection curves can be wrapped in surface......
Using wrap feature we can emboss,deboss or scribe the curve on spline or curved surface....
Other tools like split line or projection do not cover the curve completely...but wrap feature wrap the curve on to that surface completely with accuracy level.
