SOLIDWORKS TUTORIALS & HELP
Created by CadXblaze on 11 June, 2020
how to import .sldasm file for autodesk maya..
hai,, sir . i am working for 3d animator. ho
how to import .sldasm file import in autodesk maya...any plugins are.manual. sir pls..explens.,,,,..anu tutorial..pls..pls...help sir..
Autodesk DirectConnect supports the import of SolidWorks part *.sldprt and assembly *.sldasm files into the Autodesk Alias, Autodesk Maya, Autodesk Showcase, Autodesk Opticore Studio, and 3ds Max/3ds Max Design software.
Import SolidWorks files
Note: Solidworks and Maya should be installed on the same machine in which you are importing
1. Choose the menu path in your installed Autodesk software product:
Autodesk Maya (Windows version) File > Open Scene or File > Import
2.Select a SolidWorks part (*.sldprt) or assembly *.sldasm file. If you cannot see the files, start the SolidWorks software, minimize its window, and then try again to open the files.
3.Click OK, or Open to launch the translator and import the file into the scene.
Note: To maintain the original positioning and orientation of part files in your scene, import the assembly file. Importing part files before the assembly file positions all of them at the origin (0,0,0) and removes the original positioning.
Type of data imported
The software imports NURBS for this file format and maintains the following information on import:
Precise geometric surface and topology information
Data organization
Tolerances and unit
Colors
