Hi,
Just a question about how you can make a reflector in Spaceclaim. It is a round shell with radius which needs to have some reflectors on the inside.
Any thoughts would be nice
draw base circle dia. Pull up to suit, use the MOVE tool, select top face, use the green move axis and create the angle. Then round off the corners, finally use SHEL to suit
Hi Goodingm,
Thanks for your reply. It need to look like this:
Reflectors need to be on the inside of the housing. I've got the outside shape finished. The only thing I need to do is make the reflector bulbs on the spherical shape and radius. The balls I have now can not be used for injection molding.
create the row of spheres etc from the middle to the edge. I have removed the base of the reflector. Pattern then until you have enough, just touching from middle to edge.
Unpattern them, select item 2, pattern that around the first item, repeat for item 3, 4 etc
Got him, thanks. I have projected points onto the inner surface and inserted balls onto the points. Lot of work but I am satisfied :-)
