Does there exist such a program which can decipher engineering blueprints and convert them to models? I realize this would be extremely difficult if not impossible but I'm trying to figure out ways to speed up the process. Any helpful tips for how to approach modeling blueprints?
No, not that I'm aware of and I won't say, 'unfortunately', because I feel it's good learning experience for young designers. When I started out, my first job was to take old drawings, model the parts, build the assemblies and create explosion views of various assemblies and sub-assemblies. I learned a lot about our companies designs in a very short period of time.
I do the same thing with some of our interns.
To your question, I wouldn't say anything is impossible but, I haven't seen anything like that to date. Building the logic into a program to do so would be quite the feat.
Basic tips:
I'll add more later.
I should also add.... template parts, master parts, whatever naming convention you like for them.
Especially if your doing lots of similar designs, they can come in really handy. Edit a few sketch dimensions and/or parameters, and you're done with the bulk of the new design.
I work with a lot of similar designs for a range of part families. The first time around, I create a master model and parameterize all of the dimensions I may want to drive later. I often find myself going back to the master to create another similar-but-different part, which saves a chunk of time.
Програма яка розпізнає креслення і на його основі побудує модель покишо немає. Але в програмі Inventor э можливысть використовувати як основу для моделюваня файли в форматі DWG.
The program which recognizes the drawing and on its basis will not build the model yet. But in Inventor it is possible to use DWG files as a basis for simulation.
