AUTODESK INVENTOR HELP
I was designing a spring for the hammer on my grenade and i want to make it flexible. The project is uploaded (drawings included) any advice? (also likes would be much appreciated!)
You could create an assembly parameter for the length of the spring and push that assembly parameter value to the spring part using iLogic. Within the spring part, use this length parameter to control the height of the spring, using the "Revolution and Height" option for creating the coil shape. This should give you the desired results. If you have any questions, please do not hesitate to contact me. Hope this helps and have a most blessed night!
Peace,
Pete
