Can anyone tell me what softwares require to design a locomotive bogie.
I'm working as a rolling stock engineer and i aspire to work in design. It would be a help if anyone suggest me the softwares required to design a locomotive bogie.
Hoi Gaurav,
you can use different kinds of software, for desing a locomtive boge. I think you should use a 3D program, because you can do a lot of calculations with it, but al is depending of the knowledge you have and how good you are able to work with the 3D program.
I should use Inventor, because I am used to work with that program.
If you want to try a program, this is a link for students, where it is possible to install a full version of Inventor ( or other ) for free.
https://www.autodesk.com/education/free-software/featured
Here is a link that can be interesting for you:
https://www.skf.com/group/knowledge-centre/engineering-tools/skf-bearings-housings-units-and-seals-cad-models-general-instructions.html
Greetings,
Danny
