CATIA V5. Help, please: can not see spline control points.
Hello.
Can not see control points of splines in CATIAs Sketcher (please see attached image). Is there setting to show / hide spline control points in CATIA V5 or it is just bug of software?
I solved the problem.
When increasing Pixel Culling Static parameter (Tools>Options>Display>Performance) higher than 4 ,control points of splines became invisible. Maybe sometime I increased this parameter to make visualisation detail level better.
In any case, thanks for your response!
If you want to see the points, then go into the spline sketch, select the control points from the tree and make them standard elements.
Answered with a tutorial: https://grabcad.com/tutorials/catia-v5-help-please-can-not-see-spline-control-points--2
Aaah, now I got you! Use the graphic properties and switch to "fat" points.
Answered with a tutorial: https://grabcad.com/tutorials/catia-v5-help-please-can-not-see-spline-control-points--3
Devinez ce que mon camarade aime à le dire, "Altitude est déterminée par l'attitude." Néanmoins, «Il est six d'un côté, demi-douzaine de l'autre." et aussi pour le moment, je ne vais know.we aller plus en détail, mais vous devriez le prendre très seriously.Once vous avez trouvé un Nitro Slim que vous êtes intéressé à vous pourriez avoir à lire à ce sujet http://health786france.com/nitro-slim-forskoline-extraits/
