create a BOM withmore than 1 language description, Name....
Hello,
What is the best practice to get a BOM with duplicate property in different language, i.e. Description, name, material..
For exemple, if a part got a name, material, title in chinese, it will be much more practical to get it in english as well on, the next column.
Thanks
A custom (or re-purposed stock) file property and an extra column in the BOM to reference it would work, but it would be a manual entry. You can cut and paste the translation into a text type cell in the properties list.
I'm not familiar with a way to get the system to automatically use a language other than the one it is installed with, so this is the workaround I would use until I found a better way.
