Hello, Does anyone have experience with AutoCAD API (AutoLISP, AutoCAD JavaScript API)?
Creating a railing design application using the AutoCAD API can be a great project. It would involve using the AutoCAD API to interact with drawings, create and modify objects, and provide a user interface for designing railings. Here's a general outline of steps you could follow:
1. Familiarize yourself with the AutoCAD API: Start by understanding the AutoCAD API and its capabilities. Learn about the available documentation, libraries, and resources provided by Autodesk.
2. Define the requirements: Determine the specific features and functionality you want to include in your railing design application. Consider aspects such as railing types, materials, dimensions, and customization options.
3. Design the user interface: Create a user-friendly interface for your application that allows users to specify parameters for the railing design. This could include options for the railing style, height, length, posts, handrails, and other details.
4. Implement the logic: Use the AutoCAD API to translate the user input into actual drawing objects. You'll need to programmatically create the necessary geometry, such as posts, balusters, and handrails, based on the user's specifications.
5. Provide customization options: Offer customization options for the railing design, such as different styles, materials, and configurations. Allow users to modify and adjust the design interactively.
6. Validate and visualize the design: Implement validation checks to ensure the generated design meets certain criteria, such as compliance with building codes or safety standards. Provide visual feedback to the user, such as 3D or 2D renderings of the designed railing.
7. Export or generate reports: Allow users to export the railing design as a CAD file or generate reports with detailed information about the design, including material lists and dimensions.
8. Test and refine: Thoroughly test your application to ensure it functions correctly and handles different scenarios. Gather feedback from users and make any necessary improvements or enhancements.
Remember, implementing a railing design application using the AutoCAD API can be a complex task, so it's recommended to have a solid understanding of programming concepts and the AutoCAD API itself. Taking advantage of available resources, such as documentation, tutorials, and forums, will greatly assist you in developing your application.
Hello. I have extensive experience using the AutoCAD API. In my case, I used VBA for Applications (VBA 6.0).
From creating the script, to adding the program to AutoCAD by importing modules, creating the icon in the toolbar, and creating the context menu.
You can use almost all AutoCAD operations from the API. However, you cannot use operations related to OLE objects (the program waits for the operation to be entered manually).
If you'd like more information, let me know.
