Help convert IPT to Step
Hi guys
Can someone export to step the attached file (.ipt)?
Thank you in advance
Accepted answer
You can find attached 2 STEP-File variants
7 Other answer
Could you please export to step the attached file (.ipt) as well ?
Thank you so much.
Hi guys,
Could somebody please export to step the attached file?
Go to File and then choose export -Cad format- Go to the bottom and change from .dwg to .step and save.
Thank you so much.
