How and where i can use geometry analysis in solid works.
I need help.
3 Answer
waste of time
Select "Tools" and select "compare" then click "geometry".
You can analysis your part compare with the right model.
But if you want analyze the single model or just want to know face or edge or etc, select "Tools" and click "Geometry Analysis" then check or input what do you want to know then "Calculate"
You can't analyze it but can change.
