How can I add part or assembly files in Siemens Process Simulate??
I am having trouble with uploading the .jt files in Siemens Process Simulate. I have the .jt files which I converted from Solidedge. As the software only accepts .jt format files. Still I cannot add files on the software. It says on the internet that you need to create, a System Root folder followed by Co.Jt folder and finally put .jt files over there. I don't know how I can fix this issue. If someone has any idea please help me out. Thank you.
