How can I fix this problem ??
When I try to open the file in Solidworks, I get this warning. Also it have never recorded when the "auto-recovery" option is turned on unfortunately... This file very important to me, please help.
"An error was encountered while trying to open your file. Contact Technical Support for a possible solution"
3 Answer
I too am having the same problem to open the assembly file, its part models are also not opening in solidworks 2014, please help me find the solution to it.
Your files does not support in my solidworks..
Problem is "an error was encountered while trying to open your file "
Are you trying to access the file from a network location? If so I can think of 3 things to try:
First, try opening the assembly in SolidWorks eDrawings, if that loads it fine it should indicate an issue with your SolidWorks program or if it can't load it then it would indicate a problem with the assembly file itself.
Second, try copying the file to your local drive and opening it from there.
Third, if you can, try having another user's computer open the file.
