HOW DO YOU GIVE A COMPRESSION SPRING WITH DYNAMIC MOVEMENT SIDE DEFLECTION
I HAVE GOT TWO COMPRESSION SPRING'S BETWEEN TWO PLATES WHICH MOVE BOTH UP AND DOWN PARALLEL TO EACH OTHER, BUT CAN ALSO BE MOVED AT AN ANGLE TO EACH OTHER , IT'S IN THIS SITUATION THAT THE SPRING'S SHOULD FLEX IN A CURVE WHILE THE PLATES ARE IN AN ANGLE TO EACH OTHER BUT ALSO COMPRESS. HOW CAN I ACHIEVE THIS IN AN ASSEMBLY FEATURE IN SOLIDWORKS
