Hello, is there a way to get surface dimension into a drawing sheet? I'm not talking about the whole surface using the mass property, but like the measuring tools where we can clik a surface to find out what is its surface dimension.
Thanks
To my knowledge, there is no such dimensioning command. If this would be a common dimensioning case for you, I could create a macro to get the surface area. That's 100% possible with the solid API.
