How to add custom tool bar in solidworks 2011?
so that i can include commands,which are frequently used in this custom tool bar
Thanks & Regards
BP
Not sure if you can add a custom toolbar.. but you can add commands to and existing toolbar.
Answered with a tutorial: https://grabcad.com/tutorials/how-to-add-custom-tool-bar-in-solidworks-2011
If you are using the command manager, then you can add your own custom tab with whatever buttons you want. Go up to Tools>Customize. Right under the Command Manager, you will see activated tabs and unactivated tabs. There is also a "New Tab" option that will create a blank tab. Click that, then add features to your hearts content.
