How to assemble patterns in solid edge ?
Guys im trying to assemble two parts with matching patterns .Thus i got a car wheel with holes on it and a hub with bolts on it .Therefore can somebody show me the steps i need to take to bring these two together .
Thanks in advance
To use pattern in assembly you have to have part that has been made with pattern command. It means you have to make the car wheel holes with pattern command. Firstly make one hole and then use pattern.Then assemble one bolt to it in Assembly environment and use pattern command again to assemble all the other bolts. I hope there is no need for step by step instruction, because if you use these commands there is Prompt bar in the bottom of the solid edge window that does it for me. I hope you hade any help from it.
