How to change the start point in swept command in NX8.....???????
*Specify Origin Curve
Lets you change the origin curve in a closed loop.
*Section Location
Available when you select a single section.
When a section is in the middle of a guide, these options change the resulting sweep.
•Anywhere along Guides sweeps on both sides of the section along the guide.
•Ends of Guides sweeps along the guide in only one direction, starting from the section.
